P72 tuning quiestions
I need some help Im going turbo on my gsr. Its a 1996 p72 im wondering
what options do i have for tuning my stock p72, or do i need to go OBD1?
Also what type of injectors would need to be used with a OBD2 ECU vs a OBD1.
Re: P72 tuning quiestions
Most stock obd1 and obd2 injectors are high impedance.
On either an obd2 or obd1 ecu you must run a resistor box if you end up running low impedance injectors.
My suggestion: Educate your self http://www.phearable.net/tech/efibeginnerguide.html
Figure out what engine management solutions your local tuners will tune.
Figure out how much power your going to make.
Figure out what fuel injectors/pump will perform well for your goals.
If you need help figuring this all out give us a call 1-888-236-9831
just upgrade to some 580cc or bigger for future.
Your going to want to increase ur boost as you go on trust me its addicting.
Dont forget Neptune RTP. Used it loved it. Very good tuning unit.
