s300 in auto p28
Old Mar 1, 2012 | 11:45 AM
dk=gsr's Avatar
Icon2 s300 in auto p28
is it fine to run the ecu with automatic components still intact in a manual car.
and it has a s300 installed in it already.
or do i need to desolder the components for it to be able to run it?
Old Mar 1, 2012 | 11:47 AM
dk=gsr's Avatar
Default Re: s300 in auto p28
just need someone to confirm that its safe or not.
Old Mar 1, 2012 | 11:57 AM
dk=gsr's Avatar
bump.
Old Mar 1, 2012 | 12:26 PM
mouab18c1's Avatar
You need to convert it.
Old Mar 1, 2012 | 12:27 PM
dk=gsr's Avatar
thanks. that's what i wanted, because i bought it from a H-T member here and he said that it works fine.
Old Mar 1, 2012 | 12:36 PM
mtber's Avatar
I do not believe the s300 code will throw a code 19.
If it does simply remote rp17 and rp18 and jump rp18 with a jumper.
Old Mar 1, 2012 | 12:39 PM
dk=gsr's Avatar
can't i just remove IC15 and IC16 and don't jump rp18?
Old Mar 1, 2012 | 12:56 PM
dk=gsr's Avatar
so give it a try. and if it throws a code than convert it?
Old Mar 1, 2012 | 01:01 PM
mtber's Avatar
Correct.
You do not need to remove the 2 automatic transistors.
Old Mar 1, 2012 | 01:06 PM
dk=gsr's Avatar
ok. thanks.
Old Mar 2, 2012 | 07:05 AM
dk=gsr's Avatar
got a problem. the s300 broad is blocking rp18 and rp17.
so i can't get to it. so now do i just remove ic15 and ic1 transistors?
Old Mar 2, 2012 | 07:16 AM
mtber's Avatar
The s300 board can be removed it simply slides onto the male pins.
The ecu does not care about the IC transistors.
As I said before. Don't waste your time with it unless you are throwing a code 19.
Old Mar 2, 2012 | 08:13 AM
dk=gsr's Avatar
wasn't sure if the s300 broad was solder on. so didn't want to take the risk.
Old Mar 2, 2012 | 12:37 PM
dk=gsr's Avatar
plugged it in and couldn't install the s300 to laptop.
got the Smanager, but still no luck.
looked at the device on the lap top and it was throwing code 28.???
does it need to be converted than???
Old Mar 2, 2012 | 07:54 PM
mtber's Avatar
Converting the ecu to 5 speed has absolutely nothing to do with the USB driver or Smanager.
The s300 will function with an automatic or manual p28.
Read the Smanager help file. Read the section on usb driver.
You really should have just bought the system brand new from an authorized dealer to prevent these headaches.
I would never recommend buying a used s300. Especially because of this: http://www.hondata.com/s300_counterfeit.html
Old Mar 2, 2012 | 08:08 PM
dk=gsr's Avatar
yea i checked and it wasn't a counterfeit. Its legit.
read up the usb driver and everything is fine, but still can't install it onto my laptop.
could it be my firewall???
Old Mar 2, 2012 | 08:17 PM
dk=gsr's Avatar
found out that i was using the older version.
just got done downloading the new version, so ill give it a go tomorrow morning.
and found out that ill need to update the usb drivers.
Old Mar 3, 2012 | 10:30 AM
dk=gsr's Avatar
i am not able to install the usb driver???!!!
so what do i have to do now?!
Old Mar 3, 2012 | 11:01 AM
mtber's Avatar
Either consult the smanager help documentation http://hondata.com/help/smanager/index.html or contact the dealer you purchased the system from.
Old Mar 3, 2012 | 11:27 AM
dk=gsr's Avatar
PM was sent to him.
Old Mar 3, 2012 | 11:51 AM
dk=gsr's Avatar
ok, i'm sorry for putting you guys in this situation, but i finally got the USB driver installed.
I tried doing it the way Hondata had it in the USB trouble shot guide line, but that didn't work. Tried it manually and typed down (c:\program files\Smanger) and didn't work, and than i tried it manually again and typed down (c:\program files\86x\Smanger) or something like that and it worked.
thanks for all your help too.
now i gotta go apologize to the guy who sold me the s300.
ggDOHC
Engine Management and Tuning
Jan 1, 2009 06:40 AM
1BADEGDC2
Apr 1, 2008 07:02 AM
XzzYzzX
Mar 12, 2004 09:36 PM
vtecjj
Feb 20, 2004 01:00 PM
redline201
Feb 10, 2003 08:32 AM
