rpm stuck!
Old Feb 24, 2012 | 09:11 PM
Aylem1's Avatar
Default rpm stuck!
98 honda civic ex with a b20b and gsr tranny........i need help guys everything was fine this morning but on my way back home today, my car kept getting stuck and making a loud vwoom noise wen it gets stuck at 3500 rpms(I cant make the exact noise lol) in every gear at 3500 RPM it gets stuck and just doesnt go any higher PLUS also the needle that indicates my speed its stuck at zero!! Can anyone please tell me what it might be? Thank You!
Old Feb 24, 2012 | 09:15 PM
Aylem1's Avatar
Default Re: rpm stuck!
Old Feb 25, 2012 | 01:34 AM
7rrivera7's Avatar
Check engine light on? What code are you getting? Sounds like "limp home mode"...
Old Feb 25, 2012 | 01:59 PM
Aylem1's Avatar
how can i check to see what code it is....and i don't know if my check engine light is on because i just bought the car like 2 months ago and when i would turn on my headlights the cluster lights would be off so i might need new bulbs
Old Feb 25, 2012 | 02:06 PM
7rrivera7's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Feb 29, 2012 | 09:34 PM
Aylem1's Avatar
found out it was my ecu so i got me another one it works fine no more limp mode rpm getting stick all i need to do now is program my ecu to match my b20b specs
smokey68321
27
Nov 16, 2009 06:03 PM
civicx
Apr 24, 2008 02:45 PM
[Caster]
Sep 8, 2003 11:06 PM
markD.
Mar 23, 2003 01:47 PM
GSRdriver
Dec 25, 2001 12:48 AM
