P28 Worth it?
Old Dec 20, 2011 | 01:38 PM
540dude's Avatar
Default P28 Worth it?
Would I gain any advantages of buying a p28 and chipping it over chipping my stock p13? What's the difference? And would tuning a chipped ecu make a noticeable difference?
Old Dec 20, 2011 | 01:40 PM
10psiLsEf2's Avatar
Default Re: P28 Worth it?
slightly higher redline
a bit more agressive fuel map.
I THINK! i could be wrong.
i wouldnt buy it. you wont see much of a difference
Old Dec 20, 2011 | 01:44 PM
540dude's Avatar
so you'd just chip the stock ECU?
Old Dec 20, 2011 | 01:46 PM
10psiLsEf2's Avatar
sure. i wouldnt even do that! but! thats me i had 2 ecus chipped before
a. car ran like shittt
b. waste of money
Unless you wana chip a ecu to read fatter injectors i wouldnt bother
Old Dec 20, 2011 | 05:29 PM
mtber's Avatar
It really depends on a lot of factors.
The major factor is: What modifications does the vehicle have?
All chipped p28s are not equal. The thing that makes a chipped ecu perform is the program that is on it.
Old Dec 20, 2011 | 07:11 PM
10psiLsEf2's Avatar
yea sorry i didnt ask the mods. and engine
Old Dec 20, 2011 | 07:15 PM
GhostAccord's Avatar
And if I'm not mistaken the P13 really isn't one of the best hardware platforms for chipping. There isn't a hole lot of software/code support for them is there?
Old Dec 20, 2011 | 08:31 PM
540dude's Avatar
Yeah, I was looking at phearable's ecu's too.
I have a stock jdm h22 with headers/exhaust/intake
I actually found out that P13's aren't supported by tuning software that's why I'd have to go p28
Old Dec 20, 2011 | 08:35 PM
dk=gsr's Avatar
or if you add 50 dollars to it.
get a p72. it will be able to read the secondary runners if your still running them or you want to run them.
Old Dec 20, 2011 | 08:37 PM
You could also modify the P28 to operate the IABs (secondary runners) if you are keeping them. If you are unable to get a decently priced P28. Then a chipped and modified P06 (P28 equivalent) will do the trick. Just have to add VTEC and IAB components when they chip it.
Really depends on your engine setup what ECU will work best for you. if you don't have any big engine modifications your stock P13 will probably suffice for now
Old Dec 20, 2011 | 09:55 PM
10psiLsEf2's Avatar
then yes its worth getting a p28 and getting it chipped.
Old Dec 21, 2011 | 10:29 AM
q16racer's Avatar
Tuned....not just chipped.
Old Dec 21, 2011 | 12:18 PM
540dude's Avatar
Yeah obviously lol
Old Dec 21, 2011 | 01:15 PM
q16racer's Avatar
You would be surprised how many people think they are the same thing.
Old Dec 23, 2011 | 12:18 PM
dk=gsr's Avatar
LOL. basically the same because your burning your dyno tuning maps onto a chip and putting it in your ecu. the difference is that tuning puts your setup to its most potential. Besides how do you put IAB components into a p28.? does anyone here carry it?
Old Dec 23, 2011 | 12:43 PM
You solder them.....Just like adding VTEC to a P06.
Carry it.... no. I leave all of my ECUs stock until I get an order. Then I customize each ECU to the buyers specs. I do have a couple P28's and the IAB components in stock... you interested?
Old Dec 24, 2011 | 08:09 AM
7rrivera7's Avatar
Chipped p72 with basemap $175
Old Dec 24, 2011 | 08:55 AM
Wow that's good pricing for a chipped P72 right there...
Becoming harder to find a stock P72 for under $150-200 these days.
Old Dec 24, 2011 | 03:57 PM
dk=gsr's Avatar
Yeah interested in the IAB components. Solder my own ecus too. Pm'd sent.
Old Dec 25, 2011 | 05:23 AM
The IAB components are fairly cheap. You should be able to get them at your local electronics shop or online at digikey.com.
PM sent
Old Dec 25, 2011 | 03:33 PM
siregcivic's Avatar
b. waste of money
crappy tuner....
i can make a stock car faster just by chipping the computer and spending about 2 hours street tuning it with my wideband doesnt have to be modified to make it faster
Old Dec 25, 2011 | 08:53 PM
Yeah chipping an ECU and running it without a tune is a good example of what not to do. The power/reliability is more in the quality of the tune, not just the chipping. Basemaps are just that, a base on which to start tuning from. They should not be relied upon for running your engine.
Old Dec 27, 2011 | 07:05 PM
VegasInvasion's Avatar
I'm Huge In Japan
I have tested and working H22 basemaps for a P28 I can send you to get you started. Or if you want a custom one I can program the IAB to your A/C clutch output. It's not free though.
Old Dec 29, 2011 | 06:22 AM
jdmh2bcivic's Avatar
i have a chipped p28 eith my h23a setup it runs great i tried it with a p91 n didnt run better so i say its worth getting a p28
RA-d15b-vtecp08
Engine Management and Tuning
Sep 9, 2015 08:51 AM
MYEK3
Aug 15, 2010 01:07 PM
crazyguy
Aug 1, 2007 08:38 AM
DraginTeg93
Mar 17, 2007 04:16 PM
