Intake tuning
I tune with Freelog / Crome. I was going over some of the data and Freelog allows you to see the average/minimum/maximum for any sensor in any of the cells.
I noticed that I have significantly higher MAP readings (about 30 millibars) from 2500 to 3500 RPMs. I have read about tuning intake tube length. Would this be a way to measure best results of adjusting intake tubing without a dyno? It seems to reason that this would work but does anyone know for sure?
Higher map readings as compared to what?
You also need to take into consideration the TPS% as well. Are you seeing higher pressures in those RPM at 100% throttle?
Sure using the MAP and TPS readings in a specific RPM range you could measure the flow variations of the different intakes. If you have some sort of restriction infront of the throttle body it will show that.
I guess I should know by now that faster air is lower pressure air. Thanks for the reminder. I have a K&N filter on the stock intake tube but it isn't in a box. B18 LS with Crower 403 (stage 2) cams. I need to just break down and get the cold air piping. I was just wondering if there was any way to tune intake piping without a dyno.
yungmulacrx
Engine Management and Tuning
Sep 17, 2012 05:08 PM
bmxkills
Apr 24, 2011 11:11 AM
