obd2a d16y7 tuning help
Old Jan 27, 2012 | 03:18 PM
rallystyle's Avatar
Default obd2a d16y7 tuning help
ok i have a 96 hatch with a d16y7. i know its obd2a and it would be easyest to go obd1 chipped but it has the iacv 3 wire on the TB and obd1 ecu's can not control them. what would be my tuning options? the car is a DD so i need something reliable and i am in AK and it didnt get above -2F outside today.
on a side note when i time my car i have the distributor advanced all the way i am still down 5 degrees. the motor is stock but a catback, short ram intake and a y8 auto intake manifold. have checked the belt and it is correct on timing.
Old Jan 28, 2012 | 11:48 AM
mtber's Avatar
Default Re: obd2a d16y7 tuning help
Is your vehicle 5 speed or automatic?
Are you throwing any codes?
Old Jan 29, 2012 | 12:51 PM
rallystyle's Avatar
5 speed no codes. i can tell when driving that it needs timing.
Old Jan 30, 2012 | 09:00 AM
wmac's Avatar
stick in the service jumper or a paperclip and set the timing with a timing light.
Old Jan 30, 2012 | 11:08 AM
rallystyle's Avatar
i have done the jumper when i do timing and make sure its at operating temp.
Old Jan 30, 2012 | 01:02 PM
wmac's Avatar
then go off the red mark with a non-adjustable timing light, or an adjustable one set to 0.
provided your cam timing is correct and your crank pulley is the right one for your engine, you ignition timing will be set correctly.
Old Feb 1, 2012 | 01:26 PM
rallystyle's Avatar
as far as tuning could i run obd1 but leave the iacv unpluged tell i get a IM with a 2 wire iacv? also i was thinking the aem fic but i would like something with wb feedback so i can do a lean burn at cruise for some mpg. thanks to everyone so for for the feedback
Old Feb 3, 2012 | 08:05 AM
rclark's Avatar
it is not that hard to repin from 3 wire to 2 wire IACV. if you are going to spend the money on getting an ECU for efficiency it is probably worth the extra money to get a intake manifold from a Y8 at the same time.
here is an article list on repinning: http://technet.ff-squad.com/
hope this is what you were looking for.
titosek4
Jul 25, 2009 04:58 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
Propulsion
Sep 18, 2004 06:56 PM
integranator
Oct 23, 2003 09:40 PM
ScottEK
Nov 2, 2002 01:15 PM
