problem with " moving idle speed "
Old Dec 16, 2011 | 09:00 PM
99black_em1's Avatar
Default problem with " moving idle speed "
hi , i have an all motor B tuned with a s300. The cams have big primarys so getting them to idle was tricky. After playing with the timing , AFR, and the idle screw on the TB , it is now idling steadily at 900 rpm. Ive also adjusted the IAC duty to steady instead of dropping too low after revving. When the car is moving , and im coming to a stop , i notice that if the rpm is above 3k , and i put it to neutral , its fine. But if i let it decel in gear , and put it to neutral at around 1.5-2k , it drops low to like 500rpm , before bouncing back up ( sometimes drop too low and it just dies )
any idea on how to fix this ?
Old Dec 17, 2011 | 09:43 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: problem with " moving idle speed "
What is your fuel cut resume set at?
Old Dec 17, 2011 | 09:31 PM
"fuel cut resume" ? .. where can i find this setting in the smanager ? .. ill take a look.
Old Dec 18, 2011 | 08:16 AM
v.i.gsr's Avatar
Try playing with the fuel overrun settings in the tps paramater..
Old Dec 21, 2011 | 02:33 PM
thanks for the suggestion. I changed the percent in the fuel overrun from 0.6 to 1.3% and then to 2% without any changes ( ignition off ) . any other suggestions ?
92vtechhatch
Sep 13, 2010 08:15 PM
DeucEG
May 2, 2010 11:41 AM
ge_itr
Oct 16, 2007 05:12 PM
pvp329
Nov 14, 2005 11:04 PM
BoostedD15B7
Nov 12, 2003 05:53 PM
