B18c4 Starting problems help
Hi hope someone can help with this
Went to start the car and it didnt start it ticks over and thats all its doing doesnt even try to start what so ever no coughing or spluttering at all. I have checked for spark fuel which are fine also replaced dizzy cap coil igniter leads spark plugs fuel filter checked injectors and still having the same issue. I have also tried spraying easy start but that did not make a difference at all. The car was working fine 10 minutes before this happened. Fuel pump is also priming
Thank in advance
Thank in advance
PinkMaggit
16
Nov 28, 2008 05:25 PM
