Reading an article from Hondata about tuning basics
http://www.hondata.com/techenginetuning.html
I dont really understand it. Where it says
"-Tune for 14.7 from column 1-5, and 6 for 13.6 up to VTEC or 6k or so"
If he says this, what is the need for a dyno? Cant you enter the values in stated above for an near stock NA engine with basic bolt ons, and your car is already partly tuned for running a good set of AFRs? Forgive me for the noobness but i'm going over MANY articles on tuning basics.
Another thing i dont get with that article demo, is why ISNT he making the mixture LEANER as he goes up the thorttle position columns? Wouldnt a leaner yield the engine more power/torque, hence colums 6 and up should be greater than 14.7 to maybe in the 15 range? Also where are these figures coming from, the o2 sensor that reports back to the ECU? Does this mean if o2 sensor is not operational or non existant, no AFRs would appear on the matrix?
Re: Reading an article from Hondata about tuning basics
Lean mixtures make less power. Burning fuel makes energy, so if you burn less fuel per cycle, you make less power. You make the most power when you can use all oxygen in the cylinder, which generally occurs when the mixture is 10%-15% rich. There are some exceptions though.
Those AFR targets are just rules of thumb. They won't necessarily be best for any engine and application. The only definite is that you'll need to target 14.7 at low-mid load if you need to pass an emissions test that measures NOx.
All of these AFR measurements can only be obtained by using a wideband oxygen sensor and controller, such as the Innovate LC-1, NGK AFX, AEM UEGO, etc.
The rules of thumb are fine at first. AFR doesn't affect power that much as long as you're ballpark correct.
Disabling closed loop just disables feedback, not the oxygen sensor reading itself.
Ok so if i can get readings from the o2 sensor, then why is a wideband necessary? I mean, can the car still be tuned without a wideband?
My understanding is it replaces the o2 sensor. But some forums read that you only need the wideband in for tuning and you disconnect it after the tune and replace with the o2 sensor. Does that sound right?
I would really encourage you to read a lot more about this subject, because it has been covered in great lengths many, many times before. A quick Google search will give you a lot of information about this.
da_wesmeista
01-15-2010 07:47 AM
