e85 cold start
Old Jan 11, 2012 | 11:44 AM
acura_b18c1's Avatar
Default e85 cold start
hi i just switched over to e85 on the 1.8L LS/vtec, Ive been street tuning with the hondata s300, and so far everything feels good and butt dyno says it pullls slightly harder. im planning on renting a dyno soon to finish the tune. So far, the old problem has been cold start. Ive googled around and it seems playing with the cold start in the fuel trim % setting under parameters might help. ive also read increasing the cranking base pulse will also help. Just wanted to post to make sure all this is correct and ask for any suggestions or tips before i play with it .. thanks
Old Jan 11, 2012 | 02:37 PM
mtber's Avatar
Default Re: e85 cold start
Simply adjust the cranking fuel trim % and cranking base pulse vs ect.
Old Jan 11, 2012 | 03:13 PM
yes that was exactly what i was planning to do after googling a bit lol. i just wanted to post here to see if the "research" was correct.
so far , ive read of somebody using kpro , and they multiplied their cranking base pulse below 67 ect by 3 and had good success with it.
another question is , by adjusting all this , how can i tell if im going the right track with the increments ? .. or if i overdid it , and have to reduce a little ?
acura_b18c1
Jan 11, 2012 11:42 AM
eg:R
Engine Management and Tuning
Dec 27, 2011 07:13 PM
drewbie57
Jun 10, 2011 06:07 PM
SPOOLINmatt
Feb 9, 2011 04:49 AM
PA MATT
Dec 24, 2007 04:11 PM
