help with neptune
Old Mar 30, 2012 | 10:00 AM
89crxb7's Avatar
Icon2 help with neptune
OK so i have messed around and messed around with Neptune and cannot get my a/f ratio to change one bit. i really don't know if its cause i don't know what i'm doing with Neptune or something else. i hope someone can help. thanks in advance
Old Mar 30, 2012 | 10:20 AM
GagnarTheUnruly's Avatar
Default Re: help with neptune
Do you have live update on?
Old Mar 30, 2012 | 10:56 AM
HRTuning's Avatar
Definitely check live update and if you don't have a physical wideband gauge, so you're currently monitoring a/f through the software, make sure everything is wired and hooked up correctly.
Old Mar 30, 2012 | 01:02 PM
89crxb7's Avatar
Live updates on but I think I figured out my issue as I had my lc-1 heater ground wired wrong. Also I have read on a wiki that above 14.7 is lean and below is rich? Is this correct? I think so but making sure as when im adding fuel to the map the a/f ratio goes down and I dont wana lean out to bad.
Old Mar 30, 2012 | 02:08 PM
Yes higher number is leaner and lower is richer. So adding fuel will drop your AFR. If you don't know the difference going in I suggest you stop tuning NOW and do some research before you start messing with things too much.
Old Mar 30, 2012 | 02:15 PM
89crxb7's Avatar
I understand for the most just wanted to clarify my thoughts. Plus there are a few things that neptune has that crome free, ecucontrol and other opensource options dont have that im trying to get used too.
G-Auto*Hero
Oct 16, 2010 11:37 AM
primojoe20
Jun 22, 2008 06:00 PM
phantom5th
Sep 26, 2004 05:35 PM
SOFLSOL
Jan 24, 2004 07:44 AM
JHO_82
Oct 11, 2002 09:40 AM
