CEL and ABS lights when plugging in OBD1 ECU
Old Mar 1, 2012 | 09:04 PM
mr_munro's Avatar
Default Need help with CEL and ABS lights when plugging in OBD1 ECU
I purchased and installed a P72 OBD1 ECU into my 2001 DC2R with a rywire conversion harness, i am going to get S300 installed into it but first wanted to see if the ECU actually worked. The car starts fine but noticed the CEL was on. I jumped the service connector and noticed the CEL AND ABS started to flash. I grabbed the codes and I THINK they read code 22 for CEL and code 82 for ABS? This is my first time trying to retrive codes so if someone can verify this for me that would be great.
1.Are these codes suppose to show up when i plug in a different ECU?
2.Im guessing whatever these codes are, they are showing up because car has some features the ECU does not support.
3.Will i also need to clear these codes before getting the car tuned?
4.More importantly, will ABS work when the car eventually runs on this ECU.
5.Oh and i'm also correct to see the SRS flashing a code also?
THanks
Video below:
http://s930.photobucket.com/albums/a...=VIDEO0001.mp4
Old Mar 2, 2012 | 09:11 AM
mr_munro's Avatar
Default Re: CEL and ABS lights when plugging in OBD1 ECU
no one?
Old Mar 2, 2012 | 09:19 PM
mr_munro's Avatar
Wow, serious? no-one has pulled codes before to help me out?
Old Mar 3, 2012 | 11:27 AM
mr_munro's Avatar
help....
Old Mar 3, 2012 | 07:06 PM
mtber's Avatar
You are throwing a code 22 which can be disabled by the hondata s300.
Code 22 is for vtec pressure switch which your engine does not have.
Other then that you should be good to go.
Old Mar 3, 2012 | 07:27 PM
mr_munro's Avatar
Thanks for the reply..so i did read the flashes properly? Ill get the other answers to your PM tomorrow.
Old Mar 3, 2012 | 08:04 PM
mtber's Avatar
Yes. You don't have anything to worry about.
Old Mar 25, 2012 | 04:30 PM
mr_munro's Avatar
How exactly do you disable it with Hondata? Is it this step below?
Old Mar 25, 2012 | 04:41 PM
mr_munro's Avatar
nevermind, found it
Ownage1100
Jun 30, 2008 05:57 AM
Wayne_Curr
Apr 13, 2006 03:07 PM
dc2Rgirl
Oct 29, 2004 07:51 PM
Cozmo Kraemer
Feb 17, 2003 12:26 PM
