Im in NEED OF A TUNE
Old Dec 18, 2011 | 06:47 AM
s14-13b's Avatar
Default Im in NEED OF A TUNE
ok so i just picked up a eg with a b16 turbo. i am on a p28 but its not chipped or anything. right now im kinda on a budget so im looking for the best/easiest route to go with out hurting the wallet so much. i know that hondata is the way to go but i just dont have enough to pay 600 plus a tune ya know. im in oceanside so someone around me would be great.
Old Dec 18, 2011 | 07:53 AM
mtber's Avatar
Default Re: Im in NEED OF A TUNE
1. Don't drive the car until it's properly tuned.
2. Make sure you have the proper fuel system for the horsepower you will be making (440-550cc injectors and a walbro 255 lph fuel pump will suffice for most stock b16 turbos on pump gas)
3. Make sure you are running a resistor box if you are using low impedance injectors.
4. Make sure you have an aftermarket map sensor such as a 2.5 bar if you are running more then 10 psi of boost.
5. Have your ecu chipped/socketed
6. Have the car dyno tuned
Review http://www.phearable.net/tech/efibeginnerguide.html for more details on this topic.
Old Dec 24, 2011 | 07:52 AM
TheShodan's Avatar
Moderator
^^ And yes, that's the only way to do this..
Old Dec 25, 2011 | 03:37 PM
siregcivic's Avatar
I am in temecula cali not too far from oceanside, i have a wideband and a real time programmer as well as i am able to rent a dyno if you want to go that route...
i also do chipping on ecu's if you want a street tune i usually charge $100 to hook up my wideband and tune the car, if you would like a dyno tune its $200 to start and $30 an hour after 3 hours because of the setup time i have to do using a dynapack
make sure you have injectors and a fuel pump, if your not trying to push alot of power right now you can get away without the fuel pump, but it is highly recommended
let me know if you need some help, my name is mike send me pm and ill send u my phone number
preludeh22a1
Sep 13, 2008 11:42 PM
steelies
Jun 17, 2005 12:07 AM
xxscaxx
Mar 8, 2005 02:16 PM
I Like Boost
Nov 13, 2002 09:40 AM
GruvyTune
Nov 1, 2001 01:21 PM
