ECU malfunction code
Old Mar 28, 2012 | 06:25 PM
ZombiePharoh's Avatar
Default ECU malfunction code
not sure if this is the correct place for this, but its electrical.
i have a 1992 gsr that ive had for a couple months, I've started having weird power lag issues in the mid range (if you want to read the thread on it, https://honda-tech.com/forums/acura-integra-6/92-gsr-knock-sensor-problem-3031435/)
anyways, i jumped the connector and checked for codes and got a 0 code, indicating an ECU malfunction. I don't really know what my next step should be, the ECU looks brand new, dont think its the one that came in the car, it is a p61. dont know if its chipped. the harness looks pretty half assed to me as well. I dont know if i should get a new harness and ECU? i dont really feel like going through to try and fix this crappy harness, rather get a new one from rywire if i have to. Any help??
Old Mar 28, 2012 | 07:58 PM
GhostAccord's Avatar
Default Re: ECU malfunction code
I'm pretty sure that with a code 0 your car usually wouldn't even start.
Originally Posted by ZombiePharoh
thanks ^ never checked codes on an obd1 car, according to that its throwing a zero code when jumped. CEL remains illuminated only while paper clip is in the connector, and goes away when i take it out. not sure what that means.
If you jumped the connector and the CEL stayed illuminated, that means that there are a no stored codes. If the CEL had of shut off with the connector jumped, that is a code 0.
Have you done a compression test on the engine lately?
Old Mar 29, 2012 | 02:12 PM
thanks
i have not done a compression check.
y0whuddupb
Dec 29, 2007 07:22 AM
slowpokecivic
Feb 20, 2007 04:59 PM
hany
Jan 15, 2007 03:57 PM
carnifex
Oct 1, 2004 10:28 AM
Si91CRXxX
Jun 9, 2003 05:48 AM
