p28 or p72?
Depends on what motor you have. If you are working on a GSR (B18C1), I would go with either one. If you are using a D16z6, D16y8, or B16A1/2/3, go with a P28 instead. It's cheaper and more readily available.
its a jdm b18c. The only reason i asked this question is because the kid i bought the p72 a01 from said he used a p28 for his gsr turbo build and it was more common. I will be chipping the ecu next monday. But i guess it does not matter too much if you don't mind not having a knock sensor or secondary butterflies?
If you already have the P72 then it's better to stick with it and get it chipped and tuned. After they have been chipped. The only advantage the P72 really has over the P28 is the IAB circuit. Somehow I doubt that you will be using that on a boosted build though. Always useful as an option for anther I/O though.
Good luck with your build
ilovejdmhoes23
Jan 20, 2007 11:52 PM
GDM93Si
12
May 9, 2006 01:58 PM
