cant get engine code.
Old Mar 1, 2012 | 06:30 PM
martinoq92's Avatar
Icon2 cant get engine code.
i have a 95 civic coupe. D16z6, when i take it up to about 6k almost 7k in 3rd or 4th it varies the engine light will turn on... the car will run perfectly fine and as soon as i shut it off completly with key out and start it again the code goes away. so i cant do the paperclip trick. anyone know what it could be or how i can run a cel test with engine on? thanks
Old Mar 1, 2012 | 06:46 PM
HRTuning's Avatar
Default Re: cant get engine code.
You can jump the service connector without shutting the car off.
Old Mar 2, 2012 | 09:23 AM
martinoq92's Avatar
how i tried it and it would not blink.
Old Mar 2, 2012 | 09:39 AM
martinoq92's Avatar
anyone have a clue to what it could be?
Old Mar 5, 2012 | 12:17 AM
BobbyRodriguez's Avatar
If the light stays on you got some trouble shooting to figure!
But if it blinks it blinks just count the blinks!
But it could be a bunch of things, like you name any part inside your car and it just might be that one , see what I'm getting at! More info pls
Old Mar 5, 2012 | 05:38 AM
GhostAccord's Avatar
If you are unable to read any codes and the CEL comes on olny while your driving @ 6k-7k rpm.
Does the CEL flash or go solid at those RPMs? If it is flashing/blinking then I would say that it is a misfire issue. Check your ignition and fuel system. Plugs wires, cap and rotor would be the first thing to check.
Old Mar 5, 2012 | 08:36 AM
martinoq92's Avatar
Its solid and like I said even when it turns on car runs perfectly fine, maintenance is up to date. And I tried with car on and no luck.
Old Mar 5, 2012 | 10:27 AM
Are there any other lights that are on along with the little engine light? oil, D4 flashing, ABS, SRS....etc etc......
Old Mar 5, 2012 | 06:18 PM
martinoq92's Avatar
No jus engine. No abs. And it doesnt flash jus solid.
Old Mar 5, 2012 | 08:01 PM
martinoq92's Avatar
im going to replace water pump because i can hear it starting to go bad. which includes timing belt, tension pulley, and pump so i will see if after im done with that i can make a video and post a link so you guys can actually see what is happening and how it turns on.
Old Apr 3, 2012 | 05:34 PM
martinoq92's Avatar
ok i finally got the engine code it read
-Vtec pressure valve. code 22 it was 2 one sec blinks and 2, .5 sec blink. checked wires for omhs and they were in spec and to remind u guys it only happens in 3rd or 4th gear around 6,000- 7,300 rpm so any help would be nice. engine is d16z6 with I/H/E if it happens alot with alot of mods i will name all if needed but other than that I/H/E is fastest explanation. thanks
Old Apr 4, 2012 | 08:24 PM
martinoq92's Avatar
another update on research... oil level is fine and i change oil every 2500 miles i use mobile 1 Fullysynthetic... if oil pressure was the problem wouldnt another engine code come up or even oil light??? thanks for any help.
Old Apr 15, 2012 | 12:12 PM
martinoq92's Avatar
never mind thanks for all the help. i bypassed the pressure valve so it doesnt turn an engine light anymore and runs better than ever now.
Old Apr 15, 2012 | 04:46 PM
Gunmetal_B20_Hatch's Avatar
clean the solenoid filter...
Old Apr 16, 2012 | 09:25 AM
martinoq92's Avatar
i didnt know there was a solenoid filter? where would that be located and do i have to remove the whole asembly? also how do u clean it? will carb cleaner do or is there a procedure? thanks
Old Apr 22, 2012 | 10:55 AM
VegasInvasion's Avatar
I'm Huge In Japan
ten seconds on google:
http://preludehaven.forumotion.com/t...enoid-cleaning
moarlow95ex
Jan 16, 2014 04:00 PM
crxowner
Oct 12, 2011 02:54 PM
dallasXJ
Aug 26, 2008 10:10 AM
integraL
Mar 19, 2003 09:30 PM
