Twin Boost Solenoid's
Old Jan 18, 2012 | 02:23 PM
DA 4 Lyfe's Avatar
Default Twin Boost Solenoid's
I have the s300 with the Boost Solenoid that comes with it. I have a Benson 83MM GSR with a PTE 6265 1.15ar T4 Twin Scroll Manifold Twin 38mm WG's, etc.
I am going to be making 35psi or more and want to be able to have some traction on my bias plys for track use. (Don't really want to use slicks) and sick of blowing my tires off til 3rd gear down the track.
My question is can I add/run a 2nd boost solenoid to be able to run 6 pound springs in both my twin tial 38mm WG's and have it hold the full 35PSI?
My goal is to run 1st and 2nd gear at the lowest PSI level that the s300 will allow and hold big power up top.
So say 6psi
1st & 2nd, 6PSI
3rd, 20
4th, 28
5th, 35
Thanks in advance!
Old Jan 18, 2012 | 03:30 PM
FlewByU352's Avatar
Default Re: Twin Boost Solenoid's
Buy slicks you cheap bastard. Usually you max out tire configuration and then look for ways to get more traction. Not detune your setup because you want to run a shitty tire.
Old Jan 18, 2012 | 03:39 PM
DA 4 Lyfe's Avatar
I actaully have brand new slicks ready for the track this year. If you read my post right you would see (Don't really want to use slicks) Clearly I wouldn't buy such a big tire to DD on when I have slicks ready to go. If you actually read the rules you would understand there is NO street racing talk on this forum. Get the hint idiot?
Since you have NO idea if it will work or not you should prolly stick to calling people cheap bastards.
Back on topic can anyone help me out?
Old Jan 18, 2012 | 04:15 PM
FlewByU352's Avatar
Who said anything about street racing?
Old Jan 19, 2012 | 06:30 AM
DA 4 Lyfe's Avatar
No one did. If you wanna get all serious then just replace where I put "track" and put "street"
Old Jan 19, 2012 | 07:16 PM
FlewByU352's Avatar
This kind of illiteration can be expected by a DA lover. Seriously please read what you said in your reply, you sound like a vulcan idiot!
DA 4 Lyfe
May 28, 2017 11:09 PM
edsperformance
Jun 15, 2010 02:36 AM
PM-Performance
May 10, 2004 11:08 AM
V-SPEC 1
Mar 4, 2004 07:07 AM
DLB1994
Sep 27, 2003 11:34 PM
