6 Inputs for Voltage/Lambda Conversion Table (s300)
Old Jan 18, 2012 | 06:43 PM
Supa Troopa's Avatar
Icon2 6 Inputs for Voltage/Lambda Conversion Table (s300)
I am curious as to why there are 3 columns and 2 rows for the Voltage/Lambda Conversion Table. I bought an Innovate MTX-L and will be wiring it into D10 (ELD). I went to enter the voltages in Hondata supplied from Innovate for their wideband analog output and noticed that s300 has a total of 6 fields. I am assuming the last two columns are redundant unless specified by the wideband manufacture? I checked the help in Hondata and the image they show in the help only shows 2 rows and 2 columns . Innovate's forum did not yield results either. I attached a screen capture to better explain. Thanks.
Old Jan 19, 2012 | 10:05 AM
Spunkster's Avatar
Default Re: 6 Inputs for Voltage/Lambda Conversion Table (s300)
An additional point was added so that non-linear widebands could be used.
Old Jan 19, 2012 | 05:51 PM
Awesome. Thanks you.
98SpecR
111
May 5, 2020 09:57 AM
MyWhiteCivic
Jan 30, 2003 08:58 PM
dustin
Sep 22, 2002 07:58 PM
satan_srv
Jul 4, 2002 11:21 AM
