Problem with Automatic gearbox in CIVIC 2004
Hello
I ve got Honda civic vii , 2004 , 1.7 , 88 kw , D17A1 and I have a big problem ...
Unfortunately I disconnect speedometer during the car was included(ON) and problems with automatic gearbox begun . Automatic gearbox works malfunctioning : bad shifts gears, lint, but sometimes it is better ( but a little ) . I deleted errors and calibrate gearbox and now it is better but still not as good as it should be What should I do ? What may be the reason ? Is it possible that damaged speedometer have got influence on gearbox ?
Old Fart
Re: Problem with Automatic gearbox in CIVIC 2004
"Unfortunately I disconnect speedometer during the car was included(ON)" Say what??
Where did you disconnect the speedometer, at the cluster or at the transmission?
The automatic transmission control module needs to "see" speed to shift properly. 94
http://im2.olx.biz.id/images_olxid/2...pload-foto.jpg I disconnected these blue and green plugs .
MieszkoAnd
Honda Civic (2001 - 2005)
06-14-2016 03:33 PM
djtech
02-18-2003 10:25 PM
