Intermitant CEL
Old Sep 13, 2009 | 01:24 PM
Jenkinsal2's Avatar
Default Intermitant CEL
The check engine light seems to come on after a few minutes into a drive. When I turn the car off then turn to start agian to read the code it no longer shows up and I cannot figure out what is causing it. Nothing is running out of ordinary other then my idle surging occasionally. Car is a CRX Dx 1991 with DPFI and it is still OBD0.
Thanks!
Old Sep 13, 2009 | 01:47 PM
HRTuning's Avatar
Default Re: Intermitant CEL
Since you're OBD0, your ECU has a neat little window with an LED that flashes the codes. Try checking before turning the vehicle off next time.
Old Sep 13, 2009 | 02:22 PM
Jenkinsal2's Avatar
I have been checking and getting a single red blink. I originally thought the single blink meant a functioning ecu. Now i found that the O2 sensor could be bad I will be testing it per the manuals instructions. Thanks!
Old Sep 13, 2009 | 02:23 PM
HRTuning's Avatar
Any blinks mean there's a code, but you've discovered that.
No problem. Good luck!
Old Sep 13, 2009 | 03:18 PM
Jenkinsal2's Avatar
even when i dont have a cel the light still blinks but there is a four second pause between blinks. would that be just the code stored?
Old Sep 13, 2009 | 04:00 PM
HRTuning's Avatar
Sounds like a code 1 or 10 depending on how long the blink is. Stored, yes.
Kris's turbo
Apr 10, 2009 07:24 AM
Speed94
Nov 6, 2006 06:35 PM
wilsel
Apr 15, 2005 05:18 AM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
emanLS
Oct 20, 2003 01:15 PM
