which way to go
Old Aug 9, 2009 | 05:32 PM
Egonamikal88's Avatar
Default which way to go
Ok I my friend recently rebuild my b16 with the following...eagle rods, srp pistons 11:1 compression, balanced aftermarket crank (don't know the brand), dual valve springs, titanium retainers, stock cams, fpr, and other minor details. But my question is if my setup will run better being tuned, I'm running a pr3 obd0 on my crx. I'm a little short on cash so my friend told me I can tune the car with the VAFC controller as an option. Is that a good idea or a waste of time? Or should I save a little to get hondata? Or should I tune the car at all? Any input from guys would great...thanks
Old Aug 9, 2009 | 05:50 PM
98vtec's Avatar
moderator emeritus
Default Re: which way to go
you are on stock cams, so thats good....but you may have to retard the base timing a bit to keep the engine from detonating.
of course this is not the best way to go, but are you wanting to tune it yourself?
if you want to do it yourself, a much more cost effective way to go is eCtune or Neptune.
www.ectune.com
www.hrtuning.com
Both are very nice programs, however, you will need to buy a wideband as well.
Old Aug 9, 2009 | 07:24 PM
I don't plan on tuning the car myself....just looking for the best way to keep my engine healthy and safe
Old Aug 9, 2009 | 08:18 PM
98vtec's Avatar
moderator emeritus
contact any of the authorized tuners in your area listed on those two websites. They will take care of you.
tales sol
Jun 16, 2009 02:35 PM
b18master
19
Aug 12, 2007 09:31 AM
The Poopsmith
Aug 9, 2003 11:09 AM
infamousALLMTR
Mar 13, 2002 10:24 AM
