Having trouble reading code
Old Aug 20, 2009 | 04:11 PM
ITRiWISH's Avatar
Default Having trouble reading code
Car 95 civic/ Motor is LS/VTEC with p28 ecu runing hondata s100. I have a check engine light on, ran a jumper wire into the plug all I get is SRS light blinking and the check engine light goes off. Trying to figure out how to actually read the code so I can fix the problem because the car doesn't drive like it should.
Old Aug 20, 2009 | 06:50 PM
mtber's Avatar
Default Re: Having trouble reading code
You probably need to take the car to a hondata tuner to have them hookup a s200 module to the vehicle to pull the codes.
em1tetus
Jul 16, 2014 09:05 PM
jayjay
Jun 4, 2007 08:01 PM
o2compressor
Feb 12, 2006 05:30 PM
JunkyardDog
Dec 19, 2005 05:19 PM
thad
Apr 4, 2004 09:07 PM
