need a s300 start up map
Old Jul 25, 2009 | 02:36 PM
A13sechatch's Avatar
Default need a s300 start up map
ok i just built a itr with 920 injectors itr cams and 9:1 comp. 81mm with a full race top mount and a 35r i tried last night to start it but it was running too rich with the start up calabration that hondata lets you choose from the AFX was at 11 so i know it was too rich..i just need a map so i can move the car in and out the shop untill i can get the car tuned. can anyone help me?
Old Jul 25, 2009 | 05:19 PM
sander's Avatar
2.7(p/t)
Default Re: need a s300 start up map
Just do a map wide fuel adjustment.
Highlight the entire low speed cam angle map.
Press Ctrl-J
Enter -20%
Press enter
Drive it to a dyno if all is well from an Air/Fuel standpoint.
Old Jul 25, 2009 | 07:09 PM
thanks ima try it in the Am
Old Jul 26, 2009 | 01:00 AM
tried it didnt work to well when i went to give it throttle..any suggestions?
Old Jul 26, 2009 | 09:23 AM
Garage 808 Hatch's Avatar
make sure you have inputted the correct map sensor. otherwise it will run like anus.
Old Jul 26, 2009 | 01:44 PM
yeah i changed it back to the stock map and we were able to change the fuel map
Old Jul 26, 2009 | 02:48 PM
mtber's Avatar
If you can't figure it out, contact the dealer you bought the unit from. They should be able to assist you.
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
ONEQWKSI
Oct 27, 2008 09:17 AM
Trailz-EX
Jul 5, 2007 03:31 PM
rice4life
12
Jan 5, 2005 05:27 PM
