B18B ECU Help
Old Aug 16, 2009 | 02:59 PM
ekhatch66's Avatar
Default B18B ECU Help
I just did a b18b swap into my ek. i havnt driven it for a long period of time yet. But some people say that you need to drive it for a certian amount of time like a half our so the computer can reset and you will have the fuel curve you need and stuff. Is this true and for how long do you think?
Old Aug 16, 2009 | 04:41 PM
Ls_dx's Avatar
Default Re: B18B ECU Help
Just start it up and drive it. nothing else to it.
more importantly, make sure all your fluids are good, bolts tight and everything is checked up!
GL
Old Aug 16, 2009 | 10:12 PM
sanimalp's Avatar
$cat /dev/urandom
agreed. there is nothing else to it. The honda obd0 and obd1 ecu does not "learn" anything. all the data and programming that it ever needs is stored in rom memory and doesn't change it unless a tuner replaces the old rom with a new rom, at most basic level.
if the swap is 100% right, you should be able to start it up and run the car just fine.
JohnnyWash1
May 3, 2008 07:58 AM
G2DAB18
Dec 7, 2005 05:02 AM
doublethink
Apr 3, 2005 01:58 PM
stripes777
Mar 7, 2004 06:05 PM
dropd4door
Feb 17, 2004 07:30 AM
