OBD2B TO OBD1 conversion ?'s please help
Old Aug 10, 2009 | 10:08 AM
88MonsterSi's Avatar
Default OBD2B TO OBD1 conversion ?'s please help
My brother and i are fixing to start on his 99 civic si, were ordering a 92-93 xsi complete change over from HMO, the only thing were using out of it is the engine wich is the b16a thats 170hp, the rest of that swap is actually for my crx. now on to the questions.
Were going to be converting from obd2b to obd 1 with the conversion harness. i know if we were going to be staying 0bd2 we would have to change oil pumps for the crank sensor, since were switching to obd1 do we have to worry about the crank sensor now? also the computer coming with the swap is a pr3, can we use that or do we need a usdm ecu?
if im forgetting anything please let me know, this is the first time ive done and obd conversiona and want to make sure i get it all right so any help and knowledge is very much appriciated. thanks
Old Aug 10, 2009 | 12:41 PM
mtber's Avatar
Default Re: OBD2B TO OBD1 conversion ?'s please help
An obd1 pr3 does not use the crank sensor on the oil pump.
Old Aug 10, 2009 | 02:09 PM
nor does the p28 correct? also since we will be converting to obd1 we will have to use the obd1 distributor right?
Old Aug 10, 2009 | 02:46 PM
93turbo16's Avatar
You will need either the OBD1 or OBD2 Distributor. You just can't use the OBD0.
Old Aug 10, 2009 | 04:33 PM
mtber's Avatar
Correct, the p28 does not either. You will need an obd1 or obd2 distributor when running an obd1 ecu.
Old Aug 10, 2009 | 07:41 PM
awesome thanks guys. i think the rest will be easy cheese from here.
Glove
Jul 15, 2010 02:44 AM
88MonsterSi
Aug 10, 2009 09:00 AM
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
MniMeHatch89
May 24, 2007 09:10 PM
kbouchard1092
Jan 18, 2007 05:23 PM
