HELP HELP HELP!!!!! B16a
Old Aug 25, 2009 | 03:52 PM
kleeg9's Avatar
Default HELP HELP HELP!!!!! B16a
i need some help with fixing a problem with my car. Its an EG8 sedan. was 1.6 vtec (d series). Was running 100%. Took the engine out and dropped in a mint B16A engine out of a 94 EG6. And it wont run
So I'll explain this as best i can..
When I turn the key in the ignition one click absolutely nothing happens( I should get battery light at the first click)
When I turn it the second click the battery light comes on and the fuel pump comes on ( at this click I should be getting the oil light, battery light and the CEL)
When I turn the key to start the car it is turning over fine, it is getting fuel and it is sparking but the ecu isn't getting the signal to start the car
I had the dash out and i had the engine bay stripped to paint the bulk head. I put everything back in myself and checked everything 4 times at this stage.
EVERY SINGLE EARTH IS CONNECTED AND EVERY PLUG IS IN. Not one single wire is stripped, cut or pinched. I had dash back out tonight and checked every single wire with a multi meter...
The sir P30 ecu is what i'm using
That is all I can say.. I had a mechanic and an auto electrician look at it this evening and they couldn't see anything wrong.
Thanks very much for taking the time to read this and if anyone can help it would be greatly appreciated. If anyone needs to no anymore please ask
Old Aug 26, 2009 | 01:09 AM
kleeg9's Avatar
Default Re: HELP HELP HELP!!!!! B16a
anybody
Old Aug 26, 2009 | 07:50 AM
david974's Avatar
Just try to start it with your P28 to see if your P30 is fried
did you have CEL light?
Old Aug 26, 2009 | 08:21 AM
kleeg9's Avatar
I tried the p28 ecu and the same thing is happening on it. I tried changing clocks and still the same. I was told by a tuner that my ecu must not be getting any power or maybe earth but i checked it and its getting 12.3volts with the ignition on and it is getting earth like it should be..
its getting fuel and its sparking and its cranking over just fine but it just will not start HELP!!!
Tim Larkin
Jan 19, 2016 01:42 PM
CivicTec
Dec 5, 2010 08:55 AM
kleeg9
Aug 26, 2009 02:51 PM
all_motoref9
May 27, 2004 12:57 PM
