Switching ECU's for inspection
Old Sep 17, 2009 | 01:16 PM
Future50's Avatar
Default Switching ECU's for inspection
Concerning going OBD2-OBD1 what needs to be done prior to inspection? Is it just the actual ECU that needs to be switched out? I've read that the car has to be driven for 50 miles with the original ECU in order for it to be read. Is this true? If so, isn't there a risk of running a FI setup on the stock ECU for that 50 miles?
Old Sep 17, 2009 | 01:32 PM
93turbo16's Avatar
Default Re: Switching ECU's for inspection
I do this with my car every year.
I put the stock map sensor, stock injectors and both stock O2 sensors back in. Then put the stock ecu in. I drive it to the inspection station.. they plug it in and it passes. In PA you can pass with 2 not ready faults, atleast on a 96-98.
Old Sep 17, 2009 | 02:37 PM
Relic1's Avatar
stay out of boost and you'll be fine.
it depends on the state you're in, some states don't care about readiness flags, some do.
Here in IL, all flags have to be cleared, so you have to drive the car for a day or two on the OBD2 ECU.
Old Sep 17, 2009 | 04:41 PM
Future50's Avatar
That's such a pain in the ***.
EthanM
Apr 24, 2020 12:49 PM
junior_tm
Aug 23, 2016 04:36 PM
golfandcars
Engine Management and Tuning
Sep 8, 2010 05:59 PM
TeknikDC2
Jan 14, 2009 08:38 AM
