hondata s300 Question
Old Aug 19, 2009 | 08:00 AM
b16_swap's Avatar
Default hondata s300 Question
is buying a hondata s300 worth it for passing emissions and also performance.. or would it be worth just buyin the s100? im not too familiar with this so any help would be great
Old Aug 19, 2009 | 05:45 PM
b16_swap's Avatar
Default Re: hondata s300 Question
c'mon someone must be runnin some kind of hondata ecu? anyone?
Old Aug 19, 2009 | 06:42 PM
mtber's Avatar
An obd1 ecu will not communicate with an obd2 scan tool, hence you may not pass emissions.
Old Aug 20, 2009 | 09:58 AM
b16_swap's Avatar
dont they make a hondata ecu with a obd2b plug in?
Old Aug 20, 2009 | 11:55 AM
mtber's Avatar
No, it is an obd1 ecu with obd2 plugs....
Old Aug 20, 2009 | 05:27 PM
b16_swap's Avatar
so it looks like the only way to pass emisions on my car is to run my factory ecu (obd2b) and get rid of the codes some how...
Old Aug 20, 2009 | 05:29 PM
b16_swap's Avatar
is there an ecu that you know of that can help me pass emission? like maybe AEM or neptune or something?
Old Aug 20, 2009 | 05:51 PM
SilverEk3dr's Avatar
Neptune is same as s300, and the AEM will not communicate with a obd2 machine either. So you are still back where you started, but unless you have some crazy setup. I dont see how once a year you couldnt swap stock injectors etc. back in it and go get ur sticker.
Old Aug 20, 2009 | 06:50 PM
mtber's Avatar
+2
SD_Lurker
Engine Management and Tuning
Feb 11, 2009 04:43 AM
tub_sephiroth
Nov 18, 2004 10:27 PM
luckypon7
Aug 20, 2004 07:58 AM
COOKIEPUSS
Dec 23, 2003 08:38 AM
luckypon7
May 24, 2003 07:00 PM
