stock p30 basemap
Old Aug 19, 2009 | 12:21 PM
crxb16a90's Avatar
Default stock p30 basemap
i got a chip p28 since i dont' have any wideband o2 or tuning shop close by, i was going to install p30 basemap(203 crome) in, i tested it out, it idle rough. power band was ok, specially between 2-3k rpm
it have a little bogging on it.
once it pass 3k rpm then it pick up good, when vtec kick in. then it pull ok thu.
i saw there's another p30 base map on crome, said jdm p30. i haven't try it.
will the jdm p30 basemap work on p28? and also any good place i can get a stock base map? other then xenocron? thx
Old Aug 19, 2009 | 12:53 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: stock p30 basemap
here is a good place to get basemaps.. http://mycomputerninja.com/~jon/www....tionCodes.html
Old Aug 19, 2009 | 01:23 PM
MONSTERek4's Avatar
dude give me your email ill send you a good base map dont trip
Old Aug 19, 2009 | 03:23 PM
crxb16a90's Avatar
lol, just getting frustrate with this crap, u know when u install it, it run awesome then something else go wrong.
Old Aug 19, 2009 | 06:45 PM
mtber's Avatar
It sounds like you have other issues.
Post a list of your complete engine setup.
Are you throwing any codes ?
Old Aug 20, 2009 | 06:31 AM
crxb16a90's Avatar
no, i'm not throwing any code. i will check again.
crx b16a lsd y1tranny
itr flywheel.
i/h/e
4-1 dc/2.5 full catback
aem adjustable set at 0,0
blox manifold, 64mm opening, still have 56mm tb on it. will get a 66mm in few weeks
stock internal.
i use type r map, but thu idle and low cam, just run powerless.
high cam accel fast. i like that.
used b16a stock map, low cam feel great, drive good(but 2500-3000 bog)
after 3500 it pull nice all the way before vtec.
but high cam suck.
i use one of crome, p30 map with 4-1 header. it suck all the way, i don't know why
i use the other have skunk2 cam and other stuff b16a stock internal.
gave me good low cam, but high cam suck again,
so really type r so far for high cam work good. i trying to do some more reading, but i don't think i got enough time before friday night drag.
Old Aug 22, 2009 | 07:15 AM
mtber's Avatar
You must get a wideband gauge system to figure out what is really going on.
Have you set your distributor timing ?
What injectors are you running ?
Are they low or high impedance ?
Are you running a resistor box ?
Old Aug 22, 2009 | 01:58 PM
crxb16a90's Avatar
injector are stock b16a obd0 with resistor box.
i ran the track again last night. i ran 10.009(1/8th) with obd0 ecu and dizzy,
i installed blox manifold, obd1 dizzy(gsr), and obd1 p28 since then i ran last night.
i ran 10.12 best within .003 different all night about 8 times, i know my launch control was set too low, but my 60ft time was the same the first night i ran. so i thinking the basemap is no good for me.
i can't afford wideband, but i will invest on wideband and EGT sensor. i need a stock map on it, what should i run? i used p30 map from crome(of the application) and but idle jack up.
here's whats interesting about the run, i ran 10.009 at 70.1mph before the mod, and i ran 10.12 at 71.85mph after mod, which i ran .11 slower but gain more speed.
i wonder if i have the right map, it would do better?? cuz 200bucks for manifold and made me .11 sec slower, thats bullshit, lol.
Old Aug 22, 2009 | 02:05 PM
mtber's Avatar
Upgrading your intake manifold will sometimes make you loose power. It all depends on the application etc.
Old Aug 22, 2009 | 07:42 PM
crxb16a90's Avatar
Great. Now what basemap be close to pr3?
Old Aug 22, 2009 | 08:35 PM
mtber's Avatar
p30 would be the closest.
Old Aug 22, 2009 | 09:09 PM
crxb16a90's Avatar
So the one off the Crome program is good
right? I just set up what I need like vtec crossover then remove checksum then burn it. Then just wait for wideband?
Old Aug 22, 2009 | 09:17 PM
mtber's Avatar
Disable knock too....
Old Sep 4, 2009 | 04:50 AM
Wytek9's Avatar
I have a question mtber... What is the reason why mostly tuners dissable the knock sensor? Knock sensor pulls the timing once engine is knocking, its a safe feature.
Old Sep 4, 2009 | 09:58 AM
scmil95eg's Avatar
In a lot of cases, when you change or modify parts, you'll introduce mechanical noises that weren't present from the factory, like cams or valves that require more lash, or race bearings with more clearance, or 'loose' pistons.
I tuned a supercharged F20 two summers ago, notable to me because the VTEC engagement would consistently spike the knock sensor when there was definitely no preignition or knock. K's are mechanically noisy as well.
-sorry mtber, didn't see that was directed to you...
Old Sep 5, 2009 | 07:55 AM
mtber's Avatar
The factory honda bseries/hseries knock sensor sucks. It does not accurately pickup knock.
Furthermore p28 ecus do not support knock sensors.
crookson speed
Engine Management and Tuning
May 11, 2017 05:38 PM
petr0lb0mb
Apr 6, 2017 05:13 PM
91b18a1ls
Apr 14, 2012 01:59 AM
mtkhalid
13
Jan 29, 2009 07:03 PM
boostin350z
Dec 27, 2008 07:15 PM
