Ignition timing...searching done
Old Aug 30, 2009 | 12:57 PM
collumwr's Avatar
Default Ignition timing...searching done
Regarding the following:
2000 AV6 (J30A1)
I/H/E/TL-S cams
The scenario:
I'm about to install a Zex nitrous kit in the car (came in yesterday). In order to run it at a 75 shot, I'll need to retard the timing by 4 deg. As this is a distributorless ignition system, I'll have to do it with some sort of add-on to the ECU.
In my research, I've been unable to find any rock-solid answers for the following questions:
1. Can a OBDII>>OBD1 harness/chipped ECU be used with this car (if so...which one(s))?
2. If not, is there a piggyback (Greddy/Apexi/etc) that would allow for this (and work with VTEC) for this model car?
3. Does anyone know of a reputable tuner/dyno anywhere in the Jackson, MS area?
If there are answers out there, please direct me to them. I apologize in advance if I happened to miss out on some huge repository of info that everybody else already knew about.
Old Aug 30, 2009 | 03:35 PM
Ls_dx's Avatar
Default Re: Ignition timing...searching done
1. No, I dont think that would work....
2. I have no idea ethier.
there are some guys putting this motor in their civic.. maybe see what they are running for an ECU.. probably stock..??
hmm. this kinda sounds like uncharted territory...
Old Aug 31, 2009 | 07:48 AM
collumwr's Avatar
Icon3 Re: Ignition timing...searching done
Really need help here, folks. If anybody even knows of anybody who has done this, please send me their direction.
Thanks.
Old Oct 26, 2009 | 05:23 AM
gabe74gt's Avatar
Yes, there will be an adjustment screw which can be adjusted the advance or retardation of the ignition timing, but that can be checked with the digital ignition timer machine.
Old Oct 27, 2009 | 01:41 AM
pentaq's Avatar
take a look at SMT6. It allows to control engines up to 8 cylinders I think.
Old Oct 29, 2009 | 09:53 PM
rev-speed's Avatar
2000 AV6 (J30A1)
I/H/E/TL-S cams
The scenario:
75 shot u don t need to retard just run it at 10.2-10.7
butch schrier
Jul 10, 2006 03:04 PM
speedysir
Sep 14, 2005 11:17 PM
See Are X
Jan 19, 2004 01:58 PM
Stew Pidasso
Jul 10, 2002 07:16 AM
DaNish
Mar 8, 2002 03:04 PM
