S100, please advise
Old Sep 16, 2009 | 07:42 PM
Future50's Avatar
Default S100, please advise
I'm looking to replace the BTC and MAP controller that are running my jrsc with a Hondata upgrade. I was originally looking at the s300 but I really think it's overkill for my application. I'm not a tuner and I don't dragrace so I don't think I need all the options that come with it. My plan is to replace my stock injectors with 440's (already have upgraded pump) run at 6lbs and have it tuned. If I decide to increase boost later on, I'll have it retuned. The cost difference is huge ($200 vs $800). I also don't have a need to toggle between maps on the go. I've tried searching but it confused me even more because there been so many changes to the Hondata systems. If I understand, the s100 now comes standard with the boost option. I'm curious exactly what that "boost option" means because allot of what I'm reading says that a separate boost controller is required anyway. Could someone please clear this up for me? Also, do I need to add a solenoid?
Old Sep 16, 2009 | 07:55 PM
93turbo16's Avatar
Default Re: S100, please advise
You wouldn't need a seperate boost controler for a JRSC setup.
I would honestly just suggest contacting a tuner in your area and see exactly what they can offer you.
Also take a look into NepTune eprom as it is only $100 for the program fee which is paid for when you go to get your car tuned. The only thing you would need to supply is a chipped ecu.
But if Hondata is the way you want to go, the S100 will get the job done in the hands of a experienced tuner.
Old Sep 18, 2009 | 09:44 PM
Mike@CCT's Avatar
Formerly Mike@TSR
"boost option" allows you to tune positive pressure columns in your fuel and igntion tables. It is a must for your setup. It is standard with s100 so i guess its really not an option, lol. As 93turbo16 stated, you dont need a boost controller for your car.
You may have gotten that confused with s300 which has boost control capabilities for turbo applications. No solenoid needed for your setup.
Old Sep 19, 2009 | 07:47 AM
mtber's Avatar
Bingo......
btrim23
Feb 26, 2005 02:32 PM
00situner
Dec 24, 2004 03:45 PM
bboyoxygen
Dec 9, 2004 04:23 PM
JusT a Cx
Feb 24, 2004 05:58 PM
Acura_I-RS
Mar 3, 2003 11:56 AM
