H22a4 Tunning Help Please!
Old Aug 1, 2009 | 08:28 AM
RedCd5TX's Avatar
Default H22a4 Tunning Help Please!
I got an 1999 h22a4 in my 94 accord running with a po6 converted into p28 ecu, no knock sensor or IAB. The motor and injectors(290cc) are obd2. i'm running a map that was given to me by one of my friend. He gave me the same map that's he's running on his h22a(340cc). With that map, my run idle ackward, sputter like crazy, and throwing out lotso of black smoke. I don't even get close to 20mpg with that map. The program that was used to tune the map was Crome. Can anyone make me a better map for my set-up, intake, header, exhaust? any suggestion would be very helpful.
Old Aug 1, 2009 | 08:48 AM
Turbogixxer's Avatar
Default Re: H22a4 Tunning Help Please!
just get the car tuned.
Old Aug 1, 2009 | 08:51 AM
h46it's Avatar
Sounds like you need to change the injector size from 340 to 290. The car is just running to rich!
But like Turbogixxer says just get it tuned!
Old Aug 1, 2009 | 08:56 AM
RedCd5TX's Avatar
the injectors i'm running on right now is 290cc and the map was tune for 340cc. A dyno tune here in houston is $450. i'm not planning to have the car dyno tune until i turbo it.
Old Aug 1, 2009 | 09:06 AM
h46it's Avatar
Sorry to make myself a bit more clear. The injector scaling is wrong for your car. Rom is for 340cc and you have 290cc. This needs to be changed, if not your car is running just too rich!
Can your friend change this for you?
Old Aug 1, 2009 | 11:42 AM
GhostAccord's Avatar
You need a tune or a new base map that has been created for 290cc injectors. If you keep driving it as it is, you risk possible engine damage.
Old Aug 2, 2009 | 08:17 PM
RedCd5TX's Avatar
i've been driving it like this for about a month now. From what i understand, running rich is better then running lean. what are some outcome from running rich?
Old Aug 2, 2009 | 08:33 PM
h46it's Avatar
Running too rich is just as bad too. You can wash out rings or have fuel leak into the oil seize bearing.
Old Aug 3, 2009 | 09:22 PM
RedCd5TX's Avatar
well what are some indication of the symtom above that i need to look for?
Old Aug 4, 2009 | 11:26 AM
h22killer's Avatar
you need a put the resistor box for injectors 340 obd1
Old Aug 4, 2009 | 03:14 PM
RedCd5TX's Avatar
yeah, i'm well awared of that.
Old Aug 4, 2009 | 05:42 PM
thisaznboi88's Avatar
you need to retune it man. Not all tune are created equal, and ever motor build is different even if you have the same bolt on and stuff.
Old Aug 4, 2009 | 08:40 PM
RedCd5TX's Avatar
Thanks for all the help and suggestion guys. Who can i trust to make me a new map for my motor and set-up? any suggestion on that part guys?
Old Aug 7, 2009 | 10:44 AM
98vtec's Avatar
moderator emeritus
http://ectune.com/AuthorizedTuners/t...3/Default.aspx
http://www.hrtuning.com/pages/category/dealers
http://hondata.com/dealers.html
Mjalaly
Engine Management and Tuning
Jul 7, 2015 09:25 AM
WillU
Jun 11, 2014 01:10 PM
DC4KiD
Sep 29, 2013 06:52 PM
EFjoe91
Oct 6, 2012 11:28 AM
zach1288
Jan 10, 2009 08:53 AM
