NEED HELP FIXING A PULLEY
Old Sep 12, 2009 | 01:44 AM
rockinsbs's Avatar
Default NEED HELP FIXING A PULLEY
This is for a jdm h22. Well theres a little key looking medal thing that holds one of my pulley or cams that came off. The key looks like its broken off. Is it or its like that?
Old Sep 12, 2009 | 02:00 AM
rockinsbs's Avatar
Default Re: NEED HELP FIXING A PULLEY
anybody!!!!Help!!
Old Sep 12, 2009 | 11:01 AM
rockinsbs's Avatar
ANYBODY!!LOL
Old Sep 12, 2009 | 11:08 AM
redrumEM1's Avatar
New User
If you are talking abut the key or tab that holds the cam gear to the cam shaft, it should not be broken since it is what aligns the cam gear to the shaft. If it is not aligned right you will have serious timing problems.
Old Sep 12, 2009 | 11:15 AM
rockinsbs's Avatar
I dont know if its that. Its kinda hard to explain but its like a pulley down near where the tensioner is at. Maybe ill take some pictures later.
Old Sep 12, 2009 | 11:18 AM
redrumEM1's Avatar
New User
Is it the key for the crank pulley?
Old Sep 12, 2009 | 11:20 AM
rockinsbs's Avatar
I think so. Its like a little medal looking thing. Its about as big as a pinky. Just alittle bit smaller. lol
Old Sep 12, 2009 | 11:21 AM
redrumEM1's Avatar
New User
Keys for pulleys or gears are almost always removable. If it is removed you will see a square cut machined slot where the pulley mounts the the shaft.
Old Sep 12, 2009 | 11:26 AM
redrumEM1's Avatar
New User
http://media.photobucket.com/image/j...r/DSCF0013.jpg
Is this the gear and key you are talking about?
Old Sep 12, 2009 | 11:33 AM
rockinsbs's Avatar
hmmm. Looks kinda weird. You got a picture from the top of the gear or while its on the car? Itll probably be easier?
Old Sep 12, 2009 | 11:41 AM
redrumEM1's Avatar
New User
It would probably be best if you posted a picture of the one you have.
Old Sep 12, 2009 | 11:45 AM
rockinsbs's Avatar
Yeah. Maybe later. Thanks. Ill get back at you when i post up some pictures.
kp
Welding / Fabrication
11
Aug 30, 2008 02:59 PM
Jabinya
Aug 28, 2007 06:50 PM
RCautoworks
Mar 16, 2005 06:43 PM
ServiceAdvisor
Jul 8, 2004 10:08 PM
PatEJ6
Mar 18, 2002 10:41 AM
