hondata s300 02 sensor help!
Old Sep 15, 2009 | 12:56 PM
88 EF Hatch's Avatar
Default hondata s300 02 sensor help!
so i have s300 ems, the only code i have right now is 41 because i didnt convert my o2 sensor from obd0 to obd1. I heard i didnt have to with the s300, that i could just eliminate the primary oxy sensor code. Any body know how? thanks
Old Sep 15, 2009 | 01:47 PM
Ls_dx's Avatar
Default Re: hondata s300 02 sensor help!
Can you go in and disable o2?
Old Sep 15, 2009 | 02:13 PM
mtber's Avatar
You can eliminate the error code by simply disabling the o2 heater (look under parameters).
Old Sep 15, 2009 | 06:22 PM
postman's Avatar
disable the o2 and just run open loop. ive had better success with open loop. car tends to run smoother and can get just as good if not better gas mileage
Old Sep 16, 2009 | 07:18 AM
so running open loop is better? what exactly is open loop?
bmxtrev
Jun 1, 2012 11:32 PM
amej8
Jul 11, 2006 06:25 PM
turbo95eg6
Jul 2, 2005 08:27 PM
gsrvx
Dec 18, 2003 05:43 PM
civichybridb16a
Jul 26, 2001 04:51 PM
