AEM EMS Variable valve timing
Old Aug 9, 2009 | 06:32 PM
kmac_utah's Avatar
Default AEM EMS Variable valve timing
I have an AEM EMS on my track DC5 and I have a question about the variable valve timing? My friend just picked up a kPro and we were able to control the advancement of the cams at every RPM range. Also, we were able to make changes in advancement with the low lobe and high lobe of the cam. Is there tables in the EMS where we can do this as well? I think that my cam timing is locked at a specific degree... I have never made changes to the cam timing with the EMS... is it possible???
We were able to pick up some pretty good mid range power with the kPro by changing the advancement of the cam at different RPM ranges, I want to be able to do his with the AEM....
Old Aug 10, 2009 | 11:00 AM
slowtegkauai's Avatar
Default Re: AEM EMS Variable valve timing
You can eather adjust your ignition map or if you go to vtec options you can only advance or retard from your set ignition map. This ignition setting will only take effect when vtec is on.
Old Aug 10, 2009 | 03:25 PM
SuperTwinz's Avatar
"i take it your reffering to the VTC ?
go in the sensors > variable valve timing > valve # 2
and you should get the vtc chart, there is also a graph version in the menu..
and everything is opposite... lol 50vtc is really 0 ....remember that."
Old Aug 11, 2009 | 10:12 AM
kmac_utah's Avatar
Sweet! I found the table... so your saying that the numbers in the table are opposite of what the actual cam angle is??? So, if it has a value of '10' the can angle is at 40, and if the value is set at '50' the value is 0???
Old Aug 12, 2009 | 07:23 AM
sander's Avatar
2.7(p/t)
You must log actual cam position to see. The chart in AEM is not a representation of desired cam angle.
555R
Jan 11, 2005 05:46 PM
crxgsr91
Oct 22, 2004 05:41 AM
ranta18
Sep 21, 2004 09:39 AM
MisterMino
Jul 7, 2001 02:59 PM
