wacky rev limiter
Old Aug 24, 2009 | 09:04 AM
rick_rabies's Avatar
I'm not Rick!
Default wacky rev limiter
hi....
we went street tuning yesterday and right away set the revlimitor 82oo and did a 3rd gear pull.....5k rpm rev limit....wth?
changed it to 6000....3rd gear pull. again 5k rpm limit
changed full throttle shift, launch control stuff. tried everything..still 5k
restarted laptop and still 5k. after some fine tuning down at idle.it changed...
so now it set at 7500 and works good.
but...2step wont work now...
we set that and it worked nice 4k rpm... but i put let off the clutch and go and i hit 4k rpm and its now my revlimiter.....wtfrick.
any ideas. its like 2step and revlimit is backwards or sumthing
Old Aug 24, 2009 | 09:08 AM
93turbo16's Avatar
Default Re: wacky rev limiter
What program are you using?
Old Aug 24, 2009 | 09:15 AM
pb16b's Avatar
in addition to this, you have a constant CEL on?
Old Aug 24, 2009 | 10:06 AM
96 GSR-T's Avatar
from the engine management forum
Originally Posted by rick_rabies
gsr turbo with crome and ostrich
my cel is always on...i check it and it just stays on...
no blinks, no intermitant activity, just always on...any ideas?
Old Aug 24, 2009 | 10:22 AM
I'm not Rick!
crome. it seems to be this dudes laptop. he tried a laptop with vista and downloaded crome and he then pulled the map and it looked like a warzone.
so he got a dif laptop and downloaded crome and it pulled the map correctly.
but he cant figure out the revlimitor and launch control.
so...does the 2step and revlimitor ever get mixed up?
Old Aug 24, 2009 | 10:32 AM
pb16b's Avatar
nope
Old Aug 24, 2009 | 10:34 AM
I'm not Rick!
k thanx.....
hondadriver
Mar 10, 2006 12:51 PM
Jeff99Base
May 21, 2005 11:40 AM
TeH PLAYA
Apr 11, 2005 06:55 PM
digital sol
Jan 2, 2005 08:49 PM
93FastLs
Nov 2, 2004 07:16 PM
