high boost low boost ?'s
Old Aug 31, 2009 | 05:33 PM
adam00's Avatar
Default high boost low boost ?'s
how do you tune your cars high boost but then turn the boost down? how does the car know not to use the high boost tune is this controlled by the map sensor reading?
Old Aug 31, 2009 | 05:54 PM
mtber's Avatar
Default Re: high boost low boost ?'s
Simple, you would tune the vehicle using a high & low boost setting & tune the fuel/ignition tables accordingly.
The engine computer knows how much boost you are running due to the map sensor signal.
Old Sep 1, 2009 | 04:12 PM
b20beast83's Avatar
Can i just tune the high boost
eg 20psi and then turn down the boost anything lower?
is that safe?
Old Sep 1, 2009 | 05:49 PM
mtber's Avatar
is that safe?
As stated before, you would want to tune the car at both boost levels.
redlinetuning
May 7, 2009 08:41 AM
aalb1
Nov 15, 2005 02:09 PM
Snafu-Si
Jul 12, 2003 10:12 AM
The Poopsmith
Dec 14, 2002 01:35 PM
