hondata s300 smanager help
Old Sep 8, 2009 | 02:52 PM
88 EF Hatch's Avatar
Default hondata s300 smanager help
i just downloaded smanager from hondata, is this software difficult to get used to using? i dont want to destroy my ecu or motor
Old Sep 8, 2009 | 02:56 PM
HRTuning's Avatar
Default Re: hondata s300 smanager help
No, it's very easy to work with.
Old Sep 8, 2009 | 11:11 PM
is there like an online manual that teaches you how to use it?
Old Sep 9, 2009 | 06:20 AM
GhostAccord's Avatar
Take a look at Hondata's Tech section. Good place to start anyway.
http://www.hondata.com/stech.html
Old Sep 9, 2009 | 09:39 AM
Spunkster's Avatar
http://www.hondata.com/help/smanager/index.html
Old Sep 12, 2009 | 08:32 PM
how can i eliminate knock sensor so that i can use vtec on the s300? and I saw that there is a section to erase Fault Codes, Will the code come back on if its a problem in the sensor? is it a bad idea to clear Cylinder position sensor code?
nonvteclude
Nov 24, 2007 07:02 PM
JICEK9
Sep 3, 2006 06:42 PM
SuperImport
Apr 12, 2005 05:55 PM
johnmay19
May 9, 2002 12:58 PM
