adjusting launch control with crome?
I have a turbo gsr tuned with crome. When I got it back from the tuner my launch control was set at 5800rpms. I need to raise it a bit because Im bogging of the line at the track.
My question is how do I change it?
Thanx guys.
Thanx guys.
Yes, you have to pull the bin file off the chip, make the appropriate changes and reburn the chip use a moates.net burner or something similar.
The only alternative for this is using a ostrich programmer as it's a real time programmer and makes the changes on the fly.
blacc_ej1
13
Sep 11, 2009 10:34 AM
