auto ecu in manual??
Old Sep 22, 2009 | 05:52 PM
vy3tnamezz's Avatar
Default auto ecu in manual??
whats the worse that can happen??? ive just found out my chipped ecu was automatic and its in manual car p28-a52. ???
does it still matter if you put s300 on it.
i read a lot about people saying it will throw check engine light #19 on, but will anything else happen to it, like maybe not run right, ??
Old Sep 22, 2009 | 06:00 PM
HRTuning's Avatar
Default Re: auto ecu in manual??
No, nothing will happen other than the CEL, but you could cut out the simple resistor to change it to manual. Google will tell you how.
Old Sep 22, 2009 | 10:18 PM
mtber's Avatar
The car will idle hunt while throwing the code 19.
Old Sep 23, 2009 | 03:37 PM
scatterbrain756's Avatar
So my idle won't sit right if I do this??
Old Sep 23, 2009 | 03:55 PM
HRTuning's Avatar
If that's the case, cut the jumper for auto/manual out and you're good to go. Google will tell you all about it.
Old Sep 24, 2009 | 02:33 PM
I CRX I's Avatar
so a socketed and chipped a/t ecu will throw an code unless converted? i had some guy tell me it doesnt matter if his p28 ecu was a/t or not when chipping it. it will work without a problem. was he full of it?
Old Sep 24, 2009 | 02:42 PM
HRTuning's Avatar
It does work without a problem, once you take the jumper out or skip all of the auto stuff in the code.
Old Sep 24, 2009 | 06:27 PM
I CRX I's Avatar
so i would assume skipping the auto stuff is something done with neptune or eCtune? say for an ecu chipped on crome, would removing the jumper be necessary as i dont think it has the option for auto or manual?
Old Sep 25, 2009 | 12:36 AM
HRTuning's Avatar
NepTune supports automatics. You need to remove the jumper (RP17) to make it manual.
Old Sep 25, 2009 | 06:46 PM
I CRX I's Avatar
10/4 thank you sir.
Old Sep 25, 2009 | 08:35 PM
HRTuning's Avatar
No problem
turbotime
43
May 5, 2014 04:52 PM
E36 Guy
Jan 17, 2006 07:41 PM
MugenDC4
Jul 25, 2004 10:47 PM
your username here
Nov 29, 2003 04:58 PM
JDMCIV95
Nov 21, 2002 06:30 PM
