crome gold boost controller
Old Aug 25, 2009 | 04:28 AM
enrike's Avatar
Default crome gold boost controller
is everyone ever successfuly use this function
wich solenoid are we supose to use ?
i will try it tomorow
i was just curious to know if im loosing my time
Old Aug 25, 2009 | 06:53 AM
mtber's Avatar
Default Re: crome gold boost controller
old
Old Apr 29, 2014 | 08:14 AM
pkopalek's Avatar
Icon2 Re: crome gold boost controller
I'm reviving this guy to look at doing this for someone, and not having my research turn up a definitive answer (though I may be thinking too hard about it).
The Crome manual by vegasinvasion suggests that this does work, and to use A16, A17... A20 (somewhere in there).
Here's where my question comes in.
Much like how A11 (or a17 on jdm) is to be used for other programs as well as the PWM chip modification to the ECU, does this same PWM modification need to actually be used if you're using Crome Gold?
In other words, is it necessary to get this:
http://www.xenocron.com/hondata-s300...i7kk15nmr15577
In order to use A20 (for example) output?
It looks like the answer might be yes, as the PWM function allows the ECU itself (regardless of what output) to do the right work to make the solenoid work.
In other words, I'm assuming that the car's ECU needs to have the PWM modification done, whether you're using A11 as in many other softwares, or A20 in Crome Gold.
Or does Crome Gold's "PWM" functionality not need the ECU to be modified?
Old Apr 29, 2014 | 07:00 PM
VegasInvasion's Avatar
I'm Huge In Japan
the bottom line is you'll never get it to be accurate. it's slow and pretty much impossible to tune, because it's slow. I wish I could give you more hope, but there is none.
Old Apr 30, 2014 | 06:25 AM
pkopalek's Avatar
Edit: I understand.
It won't be accurate as far as boost output, so you're suggesting to not bother.
johnzm
Mar 18, 2008 09:21 PM
screaminvtec
May 23, 2007 10:13 PM
wicked2night
Dec 5, 2006 06:13 AM
onelowchef
Oct 11, 2004 09:11 PM
ImportHatch
Jun 19, 2002 08:03 PM
