ecu remap/chip??
Old Aug 5, 2009 | 08:15 AM
spidy3's Avatar
Default ecu remap/chip??
95 GSR, b18c1 will have fresh rebuild with itr pistons, blox IM, Greddy exhaust mani, Comptech intake...
Looking for best place to get my ecu remapped or chipped... funds are limited so cant do program (hondata, ect) and tuning.
Old Aug 5, 2009 | 10:01 AM
MONSTERek4's Avatar
Default Re: ecu remap/chip??
is your ecu socket already
Old Aug 5, 2009 | 11:28 AM
spidy3's Avatar
nope. not that I know of. I'll be taking it out sometime next week.
Do some come stock socketed? Ive just dealt with DSMs and I know some of them were eprom (socketed) stock
Old Aug 5, 2009 | 01:36 PM
pb16b's Avatar
you're in NY so i'd suggest contacting xenocron.com
Old Aug 5, 2009 | 02:22 PM
Relic1's Avatar
xenocron is always a great option.
or call around to local shops for local people.
(not sure how far away from you) http://www.lowbudgetracingnyc.com/
or check https://honda-tech.com/forums/engine-management-tuning-124/tuner-directory-2368887/
Old Aug 7, 2009 | 10:39 AM
98vtec's Avatar
moderator emeritus
run the stock ecu until you can afford tuning.
Old Aug 10, 2009 | 03:47 PM
spidy3's Avatar
so a stock ecu with that setup will be fine for a little while and not mess up a new motor?
.. I dont really know about honda ECUs and how adaptive they can be ..
Old Aug 10, 2009 | 03:56 PM
98vtec's Avatar
moderator emeritus
you have a p72 ecu correct? a one point boost in compression and minor bolt on's can be ran on the stock ecu just fine. I would likely retard the base timing (distributor) a degree from stock, however.
Old Aug 11, 2009 | 01:22 PM
spidy3's Avatar
ya its a P72 ecu. ok thanks for all info! a little nervous about the new motor deal. cant afford to have something stupid happen and mess it up.
ekgsr98
Jul 24, 2010 12:37 AM
jthrasher1
Jan 25, 2010 08:41 PM
so simple
Apr 12, 2009 08:31 PM
gsr_pimp88
Sep 9, 2006 05:19 AM
04DOHC
Aug 8, 2006 06:02 AM
