s300 disconnecting problem
Old Sep 12, 2009 | 09:03 PM
noluckracing's Avatar
Default s300 disconnecting problem
Anyone have trouble with the s300 disconnecting while tunning or with laptop connected viewing sensors.How do you solve this problem.
Old Sep 13, 2009 | 08:07 AM
mtber's Avatar
Default Re: s300 disconnecting problem
Do you have any aftermarket ignition components ?
Old Sep 13, 2009 | 10:38 AM
Yep MSD coil and digital 7.
Old Sep 13, 2009 | 11:39 AM
HRTuning's Avatar
The aftermarket ignition systems can cause interference with the s300. That's likely your problem.
Old Sep 13, 2009 | 12:03 PM
1junkycivic's Avatar
I have same
problem how can it be solved.
Old Sep 13, 2009 | 02:11 PM
sander's Avatar
2.7(p/t)
Get a USB cable with a large noise suppressor in it.
OR
Move your ignition components as far away from the ECU as possible.
Old Sep 13, 2009 | 10:04 PM
mtber's Avatar
+2
Old Sep 14, 2009 | 08:37 AM
boosted k20's Avatar
i had this happen to a few S300 ecus i tuned. all cars had stock ignition systems.
Old Sep 14, 2009 | 04:33 PM
mtber's Avatar
Make sure j12 is removed in the ecu
Old Sep 14, 2009 | 04:38 PM
pb16b's Avatar
i had many s300 and kpro's drop using my dell laptop. i've tuned many cars from stock k's to tucked setups with msd boxes 10 inches away from the s300 and kept dropping. well, my dell finally crashed and i bought a toshiba. call it what you want, but i've never dropped again - even with that car with the msd box 10 inches away from the s300, all those kpro's from the past, never happened since.
Outlaw-Hondaz
Mar 18, 2011 12:24 PM
EGKevin209
Aug 2, 2010 02:23 PM
chahsiubow
Jul 12, 2005 05:38 PM
