Scan Tool
Old Sep 19, 2009 | 09:35 PM
all-mtr-teg's Avatar
Default Scan Tool
I currently have an Actron CP9145, but recently, it's been acting up. Not getting a connection with some cars I've been trying to scan, mostly GM vehicles. Even though I have it hook up, it will read "Connect to DLC"
I've checked for voltage in the DLC pins, and all the cars had adequate voltage. I'm thinking of replacing this unit, as I do a bit of auto diagnostics for family and friends, but mostly just code reading and clearing for smog purposes. I'm looking to get a scanner in the $200-300 range, any suggestions?
Old Sep 19, 2009 | 11:06 PM
HRTuning's Avatar
Default Re: Scan Tool
Other than the ones I've developed myself, I have an Equus 3130 Innova that's never let me down... and it's cheaper than what you're looking to spend.
Old Sep 20, 2009 | 03:00 PM
silentkid's Avatar
if the car is not running the correct ecu it will not connect.
ie: obd2 car with obd1 ecu it will not connect
figured that out when it was working on some cars until they plugged there obd2 ecu back in
(i have the same scanner)
Old Sep 20, 2009 | 08:27 PM
Yeah I know switching from an obd2 to obd1 ecu will not work. These are stock chevy s10 and chevy malibu vehicles that won't connect to the scanner.
Civic--mini me
Feb 10, 2014 04:16 PM
brendan427
Oct 16, 2012 10:30 PM
FuNkDrSpOt
11
Aug 7, 2006 03:39 PM
shadykit
Sep 19, 2004 04:02 PM
