For the guys that chip ecus
Old Jul 28, 2010 | 07:11 PM
tobster's Avatar
Default For the guys that chip ecus
i just chipped my p05 when everything went well i thought till i plugged it in and of course the engine light stays constant pull jumper from J1 and it acts as it should i followed this guys directions http://www.d-series.org/forums/diy-f...-chipping.html is there somthing i missed i re checked all my solders everything looks real clean im just at a loss the only thing i didnt install from the kit was the big blue capacitor
Old Jul 28, 2010 | 07:24 PM
mouab18c1's Avatar
Default Re: For the guys that chip ecus
That was for a p28 ecu. For a p05 ecu depending on which board you have 11F0 or 1720 try xenocron's link
http://xenocron.com/install/
Old Jul 28, 2010 | 07:35 PM
tobster's Avatar
they are the same when chipping
Old Jul 28, 2010 | 08:15 PM
tobster's Avatar
installed capacitor and re soldered everything same dam thing anyone run into this i know the guy i used to work for did and he always did somthing and ended up fixing it lol
Old Jul 28, 2010 | 08:22 PM
93turbo16's Avatar
Post some quality pictures of your soldering.
Are you sure the chip is programmed?
Is it installed the correct way?
Old Jul 28, 2010 | 08:29 PM
tobster's Avatar
thats my next question it said it burnt my question is does anyone know if you dont install a chip at all lets say just leave chip out will the cel act normally? ill get pics up tommorow and i have the indent of the chip pointed out towards the plugs to the left
Old Jul 28, 2010 | 08:33 PM
tobster's Avatar
also car does run with light on
Old Jul 29, 2010 | 10:40 AM
tobster's Avatar
Fixed had nothing to do with my solders or my chipping
Old Jul 29, 2010 | 11:03 AM
93turbo16's Avatar
Instead of just saying fixed... say what the problem was. No matter how simple it might be.
Old Jul 31, 2010 | 10:55 PM
civickiller's Avatar
Idk if this will throw a cel right off the bat or even throw a cel but did you add in for the 4 wire o2
taking-back-sunday07
Apr 24, 2007 08:34 AM
eeyore357
Nov 12, 2004 05:40 AM
BoostedD15B7
Mar 2, 2004 09:29 AM
G U E C O
Jan 22, 2004 08:09 PM
Slow Egg
Mar 20, 2003 09:07 PM
