h22 crome tunning
Old Jul 9, 2010 | 03:05 PM
h22killer's Avatar
Default h22 crome tunning
somebody have a program for h22 turbo 9 psi boost but the pistons cr is 11.5 type s
Old Jul 9, 2010 | 03:09 PM
HAMOTORSPORTS's Avatar
Default Re: h22 crome tunning
Please tell me you aren't planning on running that on a basemap
Old Jul 9, 2010 | 03:12 PM
q16racer's Avatar
good luck with that.
________
Vaporizer Reviews
Old Jul 9, 2010 | 03:14 PM
h22killer's Avatar
i'm running whit that, but i program my ecu whit crome but the time at track i don't liked 13.58 1/4 mille so i want a opinion other program
Old Jul 9, 2010 | 03:16 PM
q16racer's Avatar
has the engine been tuned?
not tuned as in you found someone to make a basemap for you. Thats not a tune and isnt even in the same ballpark as a real tune.
________
Eleanor (1973 mustang)
Old Jul 9, 2010 | 03:21 PM
h22killer's Avatar
the engine is tuned but i don't like the program so i need other program
Old Jul 9, 2010 | 03:26 PM
q16racer's Avatar
sounds like you need to learn how to drive or fix your traction issue if you are only running high 13's with boost in a del sol
________
Avandia class action lawsuits
Old Jul 9, 2010 | 03:34 PM
h22killer's Avatar
i'm running now a 93 eg hatch and i run on slicks et drag radials , i don't have traction problems , but top end not give me
Old Jul 9, 2010 | 04:30 PM
q16racer's Avatar
what MPH do you run?
60 ft?
1/8th mile?
________
Daimler dk400
Old Jul 9, 2010 | 04:36 PM
Then you'd be better off re-tuning, don't load up a basemap sheesh!
Old Jul 9, 2010 | 05:33 PM
likwidchz's Avatar
At 11.5:1 Id really like to know what the ignition timing is at WOT at 9 PSI...guessing single digits..
--Aaron
Old Jul 9, 2010 | 08:13 PM
mtber's Avatar
--Aaron
Even if they are in the single digits... what the table says isnt the actual ignition timing value in most cases lol
Old Jul 9, 2010 | 09:36 PM
likwidchz's Avatar
not if you de-click the "Honda Phantom Ignition" evil checkbox! either way.. back onto subject... the motor will probably have a retarded looking tune yet it would probably make power, its not the stupidest thing I've seen in my life..
Get like a couple harbor freight tie down straps and wrap it around the head to keep it sealed under heavy boost! <------------ Ignore that.
Old Jul 9, 2010 | 09:37 PM
q16racer's Avatar
especially for crome
________
Extreme q vaporizers
Rob C
Sep 7, 2009 06:50 PM
umair
Feb 10, 2009 09:24 AM
djnikko
Mar 30, 2006 11:23 PM
explosive
Oct 13, 2003 08:36 PM
Mentat Ghola
Jul 25, 2002 10:35 AM
