problem with idle
Old Jun 29, 2010 | 08:26 PM
ef9itb's Avatar
Default problem with idle
i jus installed injectors and an omni 3 bar map sensor...and i cant get the car to idle using the crome program...i put the fuel multiplier to 650cc injectors...was running good before with stock injectors and stock map...now runs like crap...no matter what i do to the map it runs like crap...need help...
Old Jun 29, 2010 | 08:27 PM
mtber's Avatar
Default Re: problem with idle
You must create a new tune & select the new map sensor, fuel multiplier & start from scratch...
Old Jun 29, 2010 | 08:51 PM
ef9itb's Avatar
i did..i have the ostrich connected...made a new map...selected xenocron 3 bar map sensor...still cant idle...started from scratch...idle runs rough and i gotta give gas to keep it alive...
Old Jun 29, 2010 | 08:57 PM
ef9itb's Avatar
runs good after while driving at higher rpms and afr's are good also after driving around...once i come to a stop...it dies
Old Jun 29, 2010 | 09:05 PM
ef9itb's Avatar
jumper j1 is cut...does that need to be reconnected???
Old Jun 30, 2010 | 06:39 AM
mtber's Avatar
If j1 isn't hooked up you are running on the stock ecu rom....
Old Jun 30, 2010 | 12:27 PM
ef9itb's Avatar
ok i connected it...got it to idle now cant drive...once under load it just dies down...
ashb82
Engine Management and Tuning
11
Aug 3, 2012 01:22 PM
jonman27
Oct 22, 2010 01:25 PM
wilham320
Jun 10, 2009 08:25 PM
import810
Jul 17, 2007 11:34 PM
meanteg
Jun 26, 2003 04:56 PM
