obd0 to obd1 harness help
Old May 18, 2010 | 07:40 PM
craig88crx's Avatar
Default obd0 to obd1 harness help
on the harness for switching from obd0 to obd1 there is a wire for scs i think its called says you dont have to use it but if do to wire it to a toggle. its for checking engine codes. how do i wire it to a toggle and how does it work. thanks
Old May 30, 2010 | 08:17 AM
94dxcoupe's Avatar
Default Re: obd0 to obd1 harness help
I believe it just goes to a ground. Put a toggle switch inline, whenevr the wire is grounded it works like jumping the service connector on obd1 cars and will flash any codes on the check engine light on the dash.
spooncivic01
Sep 1, 2015 03:22 PM
my1992cb7accord
Dec 15, 2011 09:47 PM
ITA50
Apr 9, 2007 05:16 PM
