wtf.
Old Jul 30, 2010 | 10:37 PM
teamjdm239's Avatar
Default wtf.
i have a ls-vtec in my rhd integra.
the car ran hard as hell, but vtec wasnt engaging like i wanted it to.
so i pulled the computer out, and reburned a map onto the chip.
i put the chip back in, and it wont run without a check engine, the car has a sporadic idle (kinda like the iacv is bad) and the car feels super sluggish(check engine on too).
i put in a chipped p06 computer on stock p06 map, and it runs with no issues, idle or normal driving(check engine off).
when it would run with the check engine,and chip, i would use the 2pin jumper to read the code it was throwing. i turn the ignition on, and its solid.(no blinking what so ever)
so i cant retrieve a code, but its throwing a check engine.
also i must add that when the car is idling funny (at 2k) with the cel, i **** with the wires going to the ecu, the car starts dropping in idle, and fluctuating between high and low.
please some help would be appreciated.
Old Jul 31, 2010 | 01:11 PM
teamjdm239's Avatar
Default Re: wtf.
sweet. no responses
Old Aug 17, 2010 | 12:51 AM
v-tecnition's Avatar
Default Re: wtf.
sweet. no responses
Try Making a more appealing thread title... No one wants to read " WTF "
Old Aug 17, 2010 | 02:22 AM
mouab18c1's Avatar
Default Re: wtf.
Could be a bad basemap
Old Aug 17, 2010 | 08:47 AM
shoemaker617's Avatar
Default Re: wtf.
Did you try burning it on a completely different chip?
Old Aug 17, 2010 | 03:00 PM
CRX Si69's Avatar
Default Re: wtf.
try a different ecu.
Old Aug 17, 2010 | 07:40 PM
Sr420Det's Avatar
Default Re: wtf.
sounds like u should start with the connections to the ecu
Tyson
Oct 10, 2011 08:18 AM
teamjdm239
Jul 31, 2010 11:23 PM
GRANT!
Apr 10, 2010 06:33 AM
DannyITR
Jul 21, 2004 05:10 PM
eternal21
Nov 13, 2001 09:28 AM
