IS p28 USeless until fully chipped?
Old Jul 1, 2010 | 01:50 PM
SMOOTHN's Avatar
Default IS p28 USeless until fully chipped?
I have a p28 converted to 5-speed... I had some of the parts to chip the ecu but im missing the IC and the Dip socket and basemap.
Since I already added the capacitors and resistors an jumped J1. IS the ECU usless until i throw a basemap on it?
THANKS AGAIN GUYS...
Old Jul 1, 2010 | 02:48 PM
HRTuning's Avatar
Default Re: IS p28 USeless until fully chipped?
Disconnect J1 to run stock code. Jump again when ready.
Old Jul 5, 2010 | 11:49 PM
SMOOTHN's Avatar
Thanks HRtuning .
MY p72 runs better on my b20vtec, prolly cuz its for DOHC. I have a chip kit coming from Facetuned.com, they are burning my basemap for me. So the p28 will sit until the kit gets here.
Old Jul 6, 2010 | 02:28 PM
HiProfile's Avatar
If you have a p72 and the knock sensor is hooked up, use that till you get something better. The p28 will have less fuel & less timing, vtec x-over too low, and much lower redline.
Just make sure you check your spark plugs to see if the basemap is too lean or detonating if you plan to run it like that for a while.
RA-d15b-vtecp08
Engine Management and Tuning
Sep 9, 2015 08:51 AM
Crimson_Tide
Mar 19, 2006 09:01 PM
nota-eg
Jun 24, 2005 08:28 AM
Vic Nyce
Apr 3, 2003 03:42 PM
khang77642
Sep 3, 2002 06:06 PM
